1994 Acura Integra No Start No Spark
RIDETHROUGHLIFE
  • 13 POSTS
My problem is different from the rest of the 'car will not start' problems. I just purchased this 94 integra 1.8 LS and did a tune up on it- [plugs, wires, cap and touched up the rotor by smoothing out the fiber with a file] I intended to replace the rotor with a new one, but the access bolt was too tight and I couldnt get it to budge, instead of breaking it, i just smoothed the old rotor out. I got a quarter mile down the road when the revs dropped to 1500 and the gas was non-responsive and then it proceeded to die. After we got it back, we inspected it for gas in the cylinders, there was. We made sure the rotor was spinning and it was. The car cranks hard, but it just wont catch. Ive read the rest of the posts and have norrowed it down to a big list. It seems like the ICM, the coil or the distributor itself, as well as maybe being a sensor. Im smart enough not to go out and buy everything to make it work, Id like an opinion first. I did find out through my research that I had put two of the wires in the wrong spot on the D cap, but Ive since corrected it, but it still wont start. PLEASE let me know, Im dying to get my new car working again.
Aug 2, 2007 at 2:43 PM
SERVICE WRITER
  • 9,123 POSTS
Is there spark getting to the plugs?
Jan 24, 2017 at 1:08 PM
RIDETHROUGHLIFE
  • 13 POSTS
We really do not know. I am guessing that there is not though, because there is gas in the cylinders, and it would not ignite if it were getting spark. i will have to check it tomorrow, any suggestions about how to do it by myself?
SERVICE WRITER
  • 9,123 POSTS
Using a spark tester would be the best way, but what I would try first is putting the old cap back on. I always replace distributor cap and rotors in pairs, with the same brand. A slight manufacturing discrepancy causes problems like this. If she runs, then you will have to face that dreaded screw.
RIDETHROUGHLIFE
  • 13 POSTS
Okay, we tested for spark, and there was none, and because of that, it did not start with the old cap back on. my grandpa stripped out the screw, i should not have let him do it, but it is ruined now, i do not know what i can do about it now. i would really hate to get a new distributor.
CLEAVAGE4U
  • 69 POSTS
Try to drill it out. if not call the junkyard for a used one or get a re-manufactured one.
RIDETHROUGHLIFE
  • 13 POSTS
would it be a feasible option to take the distributor off and try to get the rotor off and get the ICM and ignition coil checked out. i know Autozone checks the ICM, but where can i get the coil tested? or is there a simple test i can do?
SERVICE WRITER
  • 9,123 POSTS
I "think" you can check the ohm reading against a new one, but maybe someone can elaborate better.
Jan 24, 2017 at 1:09 PM
BRUCE HUNT
  • 3,754 POSTS
If there is voltage at the coil of twelve volts in and nothing out replace it.
RIDETHROUGHLIFE
  • 13 POSTS
oh thanks you guys, your information really helped me out. my car is running fine now and we have since gone on a hefty road trip in it, no problems at all. i really appreciate all the help.
SERVICE WRITER
  • 9,123 POSTS
Hey, what was the solution? the coil? (thank-you Bruce!!)
RIDETHROUGHLIFE
  • 13 POSTS
i am really not sure, we got the bolt free finally, after we drilled it, and i replaced the ICM and the coil. it could have been either, but i went on a road trip 1,200 miles and it has worked like a charm.
Suggested Repair
Confirm there is no spark at the plugs. Check for about 12 volts into the ignition coil and no output; replace the coil if that is the case. Also consider the ignition control module and a matched distributor cap and rotor. In this case, freeing the stripped rotor screw and replacing the ICM and coil restored starting, though which part failed was not confirmed.
Conversation Summary
A 1994 Acura Integra 1.8 LS cranked but would not start after a tune-up that included plugs, wires, a distributor cap, and smoothing the old rotor. Fuel was present and the rotor turned, but testing showed no spark, and reinstalling the old cap did not help. The rotor screw was stripped and later drilled out. Experts advised checking spark, replacing the cap and rotor as a matched pair, and replacing the coil if it had voltage in but nothing out. The owner replaced the ICM and coil, after which the car started and ran reliably, though it was unclear which part fixed it.
