Can anything go wrong???
ASIAN DAVE
I have a 91' Acura Integra. Its About 156,000 Mile on it. Its a 1.8 DOHC. I recently did a piston ring & head gasket & oil pan gasket change on it thinking since it had all that mileage on it. Then I got injured and left everything where it was until I recovered from my injury and that was for 3 yrs. Yeah, It was sitting in the garage that long. So, now that I had put everything back into the car and hook it all up like how I took it off now the car dont start. I check all the fuses thinking I could've burnt some out but all the fuse is still good. Then, I'm checking and checking and found out I'm not getting sparks and my fuel pump ain't working. I just like to know can that type of stuff happen when things just don't work when the car Is sitting for awhile??? :D
Jul 22, 2007 at 1:54 PM
BRUCE HUNT
  • 3,754 POSTS
Your EFI relay could be bad on the fuel side and the electrical side could be a sensor such as the cam or crank position sensor. I would see if I had spark to the ignition coil.
Jul 26, 2007 at 8:54 AM
