1995 Acura Integra ABS Light On
NICKYWU
Hi. I have a 95 acura integra with 133k miles. My question is what is the problem with my car if the abs light comes on and stays on when the car starts? The weird thing is that it doesn't always stay on though. If I were to turn off the engine, and come back a while later, there is a chance that the light will come on, while other times it won't. I hope you guys can help. Thanks a bunch!!
Aug 16, 2007 at 5:53 PM
BRUCE HUNT
  • 3,754 POSTS
I often start with an ohm meter and read the wheel speed sensors. with the engine off unplug each wheel speed sensor. Each of them should read somewhere around 700 or so but what you are looking for is the one that does not change the ohm meter. There is also a way to plug into the ABS to get a code out of it. can anyone else give them some pointers on pulling the codes?
Aug 20, 2007 at 9:52 AM
Suggested Repair
With the engine off, unplug each wheel speed sensor and check resistance with an ohm meter. Readings should be around 700 ohms; look for a sensor that does not change the meter. Also retrieve ABS diagnostic codes.
Conversation Summary
The owner of a 1995 Acura Integra with 133,000 miles says the ABS light sometimes stays on after startup and sometimes does not. An expert recommends testing each wheel speed sensor with an ohm meter for a reading near 700 ohms and identifying any sensor that does not respond, and also pulling ABS codes.
