i have a 1995 acura integra LS, 110K with a leak in the ABS that i can not find. any idea where to start?
Jul 28, 2007 at 1:54 AM
Start by inspecting the master cylinder, including the seals where the pedal rod connects to it inside the vehicle. If the pedal feels weak or sinks toward the floor, focus on the master cylinder, then inspect each wheel and the brake hoses for the leak.
The owner of a 1995 Acura Integra LS with 110,000 miles cannot locate an ABS leak. The expert advises starting at the master cylinder, including the internal seals at the pedal rod, then checking each wheel and the hoses.
