HI, i have a 2001 integra with a B20B (CRV)motor swap in it. Just yesterday i started the engine and it idle really low then shut off. i tried to start a couple times after that but it wouldnt turn over. Before it shut off i heard a knocking noise where the cams were. i removed the valve cover to see if anything was loose or came off. nothing..i did feel the timing belt...and it had alot of slack on the top and on the left (towards the front). the belt was really loose. did my timing belt skip and caused the cams to be mis aligned? would it be best to just replace the belt since a tooth may have been broken? any advice would be good right now. thanks.
Mar 1, 2009 at 5:40 PM
