2000 Acura Integra Lights Dim Then Dies
JFAINE21
Yes i was driving down the street and all of sudden my dome lights and all the lights inside the car just went dim and some turned off, the headlights got dim also. It kept driving because i still had it in gear, then when i came to a complete stop everything just died and the car didn't even start and all the lights where dim. What can be the problem? Thanks!
Sep 27, 2007 at 4:32 PM
BRUCE HUNT
  • 3,754 POSTS
I would first look at the condition of the battery but I suspect the underlying problem is your alternator. Charge up the battery and get the vehicle started. Then with it running put a volt meter on the battery and read the voltage. Anything less than 14 volts is an indication that the alt needs to be repaired.
Sep 28, 2007 at 1:11 AM
Suggested Repair
Inspect and charge the battery, then start the engine and measure battery voltage. If the reading is under 14 volts, repair or replace the alternator.
Conversation Summary
The owner of a 2000 Acura Integra said the interior lights and headlights dimmed while driving, then the car died at a stop and would not restart. The expert advised checking the battery first but suspected the alternator, recommending a running voltage test; less than 14 volts indicates the alternator needs repair.
