1999 Acura Integra Clutch
90,267 MILES • 4 CYL • FWD • MANUAL
TMPCALGUY
I just put in a stage 3 clutch 3 weeks ago. I had a different mechanic put in a Brand New Type -R LSD Transmission yesterday. I took it for a test drive and when I start off in first it sequels like a slipping belt for a second and then everything is normal. It will then do it if I put it into the next gear aggressively or Down shift aggressively. No slipping no hesitation and besides the noise all is great???? It sounds like a clutch engagement issue or disc to flywheel issue.. Throughout bearing???
I just do not know what to go for.. It is a blast to drive. I just do not want to damage my new tranny...
Any Ideas???
Troy
Apr 12, 2008 at 12:15 PM
MASTERTECHTIM
  • 4,750 POSTS
are you sure its not a slipping belt? what did the transmission guy say he thought it was? the noise sounds odd to be a transmission noise.
Apr 12, 2008 at 12:53 PM
TMPCALGUY
[quote:47bb807121="mastertechtim"]are you sure its not a slipping belt? what did the transmission guy say he thought it was? the noise sounds odd to be a transmission noise.[/quote:47bb807121]
It Only happens when I engage the clutch or feather the clutch when taking off???? Then no more noise.. Until I downshift or upshift Aggressively
Apr 12, 2008 at 1:08 PM
MASTERTECHTIM
  • 4,750 POSTS
its probably going to have to be taken out again to find out for sure.
Apr 12, 2008 at 1:11 PM
