1999 Acura Integra bad clutch
140,000 MILES • 4 CYL • FWD • MANUAL
E_PEREZ1983
I have a 1999 Integra with 140,000 miles on it. This morning when I pushed in the clutch in, it wouldn't pop back out and I can't change gears. I'm pretty sure I need a new clutch (I've never replaced mine). What's the average cost (with labor) to replace my clutch?
Jan 3, 2008 at 10:21 AM
OLDTECH2
  • 64 POSTS
If memory serves, this car has a hydraulic clutch. Sounds more like a problem in the hydraulics than the clutch itself.
Check the fluid. There should be a reservoir under the hood that is on the order of a master cylinder reservoir. It is not tied to the brakes, so make sure that you get the right one.
If the fluid is ok, then it's got a problem with either the master or slave cylinders.
Any way you go, the hydraulics are easier to deal with than the clutch.
Jan 3, 2008 at 1:03 PM
