1999 Acura Integra Codes
1999 ACURA INTEGRA
85,000 MILES • 4 CYL • FWD • MANUAL
JIMMY3STIX
  • 6 POSTS
My 1999 integra recently started to sputter and stall after going through a fairly deep puddle. The engine light came on it is throwing out 3 codes. P-0135. P-1298 and P-1508. What do I need to do to fix this. The mechanic reset the codes and the light has not come back on but the car still sputters and stalls.
Feb 18, 2008 at 3:29 AM
JEREMIAH
  • 217 POSTS
p0135-oxygen sensor,sensor 1. connector could have gotten wet.sometimes needs replacement other times not.
p1298-electrical load detector.probably just a glitch from the water.
p1508-idle air control valve.it's the cause of all the sputtering.
Mar 2, 2008 at 1:07 PM
