1998 Acura Integra weird noise in motor
SHADZ1419
  • 1998 ACURA INTEGRA
  • 4 CYL
  • FWD
  • MANUAL
  • 160,000 MILES
I have a 98 integra. Just resently I was driven and made a hard right turn, when I pulled over my check engine light was on and it was maken a weird shudering nosie. So I drove it home. But on the way home it woundNt really pick up speed. Idk what it could be or we're to start. Got any suggetions?
Saturday, July 17th, 2010 AT 7:15 AM
KHLOW2008
  • 41,814 POSTS
Hi shadz1419,
Get a free scan done at Autozone and let me know the EXACT trouble code for the CEL indicating and we can proceed from there.
Sunday, July 18th, 2010 AT 3:52 AM
SHADZ1419
I went to my buddys shop and he hooked up the scanner to my car. This is what I got?
Cylinder 1, 3 and 4 misfire detected
Random/multiple cylinder misfire detected
manufacture/control ignition system or misfire.
Sunday, July 25th, 2010 AT 4:02 PM
KHLOW2008
  • 41,814 POSTS
I can relate to the cylinder misfiring as it is quite common and most often it is due to spark plugs or fuel. Get the spark plugs checked and fuel pressure tested.
As to the last part, manufacturer/control ignition system or misfire, it could be related to the misfiring.
I requested for the exact code but you only provided the description which is not accurate as different scanner have different ways of describing and would not allow me to get the correct information.
Sunday, July 25th, 2010 AT 4:28 PM
SHADZ1419
So I was heading to autozone for them to test it. The car had little gas in it. As I was going up the hill it just died on me. I"ve beeen tryin to start it but it only attempts to start but doesnt?
Tuesday, July 27th, 2010 AT 11:28 AM
KHLOW2008
  • 41,814 POSTS
Have you topped up the gas? On inclines when fuel level is low, the fuel sways to the rear and is out of the fuel pump's reach.
Tuesday, July 27th, 2010 AT 1:09 PM
