Well sanding down the friction surfaces isn't a bad idea, but if they are really glazed over and hard then it won't really do much, you will have to replace them.
However, if those wheel bearings are loose, replace them! That is most likely you're issue
Wednesday, April 29th, 2009 AT 5:05 PM
