1990 Acura Integra poping out off gear
186,000 MILES • 4 CYL • 2WD • MANUAL
ZURI
I have slight grind on 3rd gear and when i put in 5th arter a few miles it pops out , I whant to know what can be causing this problem or if I need a new tranny.
Apr 13, 2008 at 6:00 AM
JEREMIAH
  • 217 POSTS
shift fork is probably bent, it usually happens after someone has been either slaming or leaning into the shift lever for some time,either way, its due to excessive force on the lever.
you can get it repaired instead of spending for a new transmission. it's not considered major as far a transmission problems go
Apr 15, 2008 at 10:00 AM
ZURI
thank you ill check it out , thanks for the help
Apr 16, 2008 at 12:07 PM
