1998 Acura Integra
KEOKS
  • 1998 ACURA INTEGRA
Engine Mechanical problem
1998 Acura Integra 4 cyl Two Wheel Drive Manual
oh ya and how do I install a oil gauge on this type motor thanx
Thursday, April 1st, 2010 AT 6:01 AM
KHLOW2008
  • 41,814 POSTS
Hi keoks,
If you mean an oil pressure gauge, you need to get an adapter and install the source between the oil pressure switch if the gauge is pressure operated.
If the gauge that you are getting is electricallly operated, the you need to replace the oil pressure switch with one that converters the pressure into resistance.
Thursday, April 1st, 2010 AT 9:31 AM
