1995 Acura Integra front end
DRAGONFYRE1984
Noises problem
1995 Acura Integra 4 cyl Front Wheel Drive Manual
I recently bought a 95 acura integra ls (non vtec engine) there was a noise in the front end the nearest that i can think of is a large 4 wheel drive with large tread going down the road. the noise starts at about 20-25 miles an hour and gets louder as i go faster it does not go up and down in noise with the rpm going through the gears. i changed a broken motor mount (driverside lower) and the cv arm assembly the noise has gotten a little quieter since then however the noise is still present. please any help would be greatly appreciated
Apr 23, 2009 at 5:30 AM
F4I_GUY
  • 3,302 POSTS
It may be the actual tires on the front that are causing this noise. Try rotating them to see if that helps or changes the pitch.
It's either tires or a wheel bearing.
Hope this helps
Apr 23, 2009 at 10:39 AM
