1995 Acura Integra Blue smoke
1995 ACURA INTEGRA
160,000 MILES • 4 CYL • FWD • MANUAL
BRIANYOO123
I see that i need to chage gasket, seal, or piston ring....
i know why it comes out because of burning motoro oil inside the engine..
however, due to lack of money i can't fix it
i'm trying to fix it but i don't know well
could you give me some instruction?
May 1, 2010 at 9:11 PM
KHLOW2008
  • 41,814 POSTS
Hi brianyoo123,
At least 70 % of grey( blue) smoke are oil consumption due to worn valve seals.
This is not an easy job for DIY and if you do not have the required tools such as torque wrenches, valve spring compressors, you would not be able to perform the job.
Normal procedure is to remove the cylinder head to perform the job.
If you have a compressor available with a special tool to apply regulated pressure to the cylinders via the spark plug holes, then there is no need to remove the cylinder head. however special tools would be required to remove the valve springs and care has to be taken to avaoid the valve collets from dropping into the engine oil passages.
May 2, 2010 at 3:05 AM
