1995 Acura Integra '95 Integra clutch slippage
215,000 MILES • 4 CYL • FWD • MANUAL
KIMCHEELOVER
It's getting harder and harder to shift from gear to gear. Also, while I'm in a gear (let's say 1st gear) and the clutch is disengaged, it feels as though it isn't completely disengaged, like it's grinding, and the car shakes fairly violently. For right now it's on and off, but it has been getting worse over a couple of weeks. Just wondering if someone can pinpoint the problem and a solution.
Thanks
Jul 9, 2008 at 10:24 AM
KHLOW2008
  • 41,812 POSTS
Hi kimcheelover,
If the clutch hydraulics and travel is ok, then most probably the clutch disc is faulty. Most probably the dampers have detached themselves from the disc, you need to have the clutch system checked.
Jul 10, 2008 at 12:57 AM
KIMCHEELOVER
[quote:9be174b3e4="KHLow2008"]Hi kimcheelover,
If the clutch hydraulics and travel is ok, then most probably the clutch disc is faulty. Most probably the dampers have detached themselves from the disc, you need to have the clutch system checked.[/quote:9be174b3e4]
Thank you for the reply. Is it possible to repair what's broken and not replace the entire clutch? Just trying to be cost efficient for it's an old car.
Jul 10, 2008 at 4:46 AM
KHLOW2008
  • 41,812 POSTS
Hi kimcheelover,
That depends on the damage and wear.
Jul 11, 2008 at 1:08 AM
