1994 Acura Integra Won't start
AI
  • 1994 ACURA INTEGRA
  • 4 CYL
  • FWD
  • 134,000 MILES
When I go to a gas station and I get my gas I turn off the engein. After I get the gas the engine will not start. When I turn the key no sound at all. But after about 2minutes or after about 12 turns with my keys it will start. This happens only when I get gas. I feel there is something to do with the gas tank. Can some one help with my problem.
Monday, April 21st, 2008 AT 1:29 AM
THEBIGGMCDOG
  • 25 POSTS
Check the harness from the starter to make sure it is not loose. Try to turn it on. If you hear a clicking sound when cranking your starter try to bang the starter if it turns on your starter is bad.
Tuesday, January 24th, 2017 AT 9:08 PM
KHLOW2008
  • 41,814 POSTS
The gas tank has nothing to do with the starter not cranking.
High possibility is starter, poor electrical circuit or a defective ignition switch which I think is your problem as you need many turns of the ignition key to get a crank.
