1994 Acura Integra RS
TODD1970
  • 5 POSTS
I started up my Acura Integra yesterday morning to go to the doctors which at that time I noticed no problems.After I seen my doctor I got back in my car to start it up but it would do nothing. I tried to jump start it with jumber cables but it still did nothing so I had to push it to get it started since it was a 5 speed which at that time it started up. Since I have been home I have changed the battery and I also put a knew starter in the car and it still will not start up. I have noticed that when I turn the ignition on it make a clicking noise near the fuse box under the hood near the battery. I also replaced the 2 relays that go inside that fuse box thinking that was the problem but that still did nothing.I had a friend tell me that there is also a relay that is inside my car on the passenger side behind the glove box that could also be my problem.If anyone has any idea what the problem may be I would appeciate any help!!
thanks!!!
Oct 29, 2007 at 9:13 AM
BMRFIXIT
  • 19,053 POSTS
[quote:36dbbb4e38="todd1970"]I started up my Acura Integra yesterday morning to go to the doctors which at that time I noticed no problems.After I seen my doctor I got back in my car to start it up but it would do nothing. I tried to jump start it with jumber cables but it still did nothing so I had to push it to get it started since it was a 5 speed which at that time it started up. Since I have been home I have changed the battery and I also put a knew starter in the car and it still will not start up. I have noticed that when I turn the ignition on it make a clicking noise near the fuse box under the hood near the battery. I also replaced the 2 relays that go inside that fuse box thinking that was the problem but that still did nothing.I had a friend tell me that there is also a relay that is inside my car on the passenger side behind the glove box that could also be my problem.If anyone has any idea what the problem may be I would appeciate any help!!
thanks!!![/quote:36dbbb4e38]
since its 5 speed standerd
u have a clutch switch
check that
(you can nt start the car if u dont push down on the
clutch )
what i m getting to is if the switch is open
you will have the same thing no start
the relay wont groung and no start
good luck
Oct 29, 2007 at 11:11 AM
