1993 Acura Integra overheating?
JERITH90
  • 1993 ACURA INTEGRA
  • 4 CYL
  • FWD
  • MANUAL
  • 160,502 MILES
My car says its overheating but its not. When accelerating it heats up but drops to normal temp when I hit 45 mph normally. The radiator was replaced and so was the therm. When over heating it blow freezing air out of the heater, but motor is not hotter and not smoking, nor spilling out coolent.
Sunday, December 20th, 2009 AT 3:21 AM
Check the thermostat again and test the engine coolant temperature switch on the thermostat housing could be out of calibration/range
Sunday, December 20th, 2009 AT 4:03 AM
JERITH90
Already did that its still overheating or at least says it is
Tuesday, December 22nd, 2009 AT 10:10 PM
Lets try bleeding it out could be air in the system that don't work-get it block and pressure tested.
Wednesday, December 23rd, 2009 AT 1:03 AM
JERITH90
I found the problem my heater control valve was leaking so air was getting in to the system
Monday, December 28th, 2009 AT 10:16 PM
