1997 Acura Integra overheating
1997 ACURA INTEGRA
142,000 MILES • 4 CYL • FWD • MANUAL
PROFILE
My acura integra 1997 continues to overheat. I changed the radiator,radiator cap,hoses,sensors both,t-stat and the water pump is opearational. The cooling fans operate but when you drive the cooling fans will not operate all of the time. The pressure inside the radiator hoses seem to be very hard when the car is running - i had the top radiator hose split. The overfill tank fills up when I run the car hard and air bubbles are present in the overfill tank during both hard and normal running conditions, i was told that is not good news. I removed the t-sat and it seems to not be overheating but bubbles in the overflow tank are still present. I dont know what else to do or change. I was told it could be a cracked head or leak internally and its best to rid of the car before it gets worse. I'm out of ideals. I love my car but the overheating problems have become a problem. Please help me.......
I have the gs model.
May 19, 2008 at 6:47 AM
THEBIGGMCDOG
  • 25 POSTS
What you need to do is first locate the bleeding housing unit thats connected the the radiator hose, once u unscrew the "bleeder bolt" at the housing unit that is located right after the radiator hose ,( u cant miss it) , unscrew it and let the air escape wth the car on until the fluid evacuates.
If that fails that check your relays fans
May 26, 2008 at 4:58 AM
THEBIGGMCDOG
  • 25 POSTS
[quote:e82c8d1665="thebiggmcdog"]What you need to do is first locate the bleeding housing unit thats connected the the radiator hose, once u unscrew the "bleeder bolt" at the housing unit that is located right after the radiator hose ,( u cant miss it) , unscrew it and let the air escape wth the car on until the fluid evacuates.
If that fails that check your relays fans[/quote:e82c8d1665]
May 26, 2008 at 5:00 AM
KHLOW2008
  • 41,814 POSTS
Since you mentioned that the pressure build up is very high, bad news, you have a gasket problem.
You would need to reface the cylinder head and most probably the block also.
May 26, 2008 at 6:03 AM
