1993 Acura Integra Bleeding brakes
1993 ACURA INTEGRA
150,000 MILES • 4 CYL • FWD • AUTOMATIC
JIMOFBETHEL
I replaced the front calipers and pads. I cannot seem to get a firm pedal. I have bled them multiple times. I did use the recommended bleed pattern. Still no luck. Brakes are very soft, still have air, brakes go to the floor. They do not work!
May 6, 2009 at 2:59 AM
F4I_GUY
  • 3,302 POSTS
Were they like this before?
You either have another problem, or they are not properly bled. Another possibility would be that the flex hose is leaking a tiny bit resulting in a soft pedal.
May 6, 2009 at 11:39 AM
JIMOFBETHEL
I believe I bled them properly. How would you recommend I do them? What is the flex hose you are referring to?
May 10, 2009 at 11:18 AM
