1992 Acura Integra Car won't start
KENN765
  • 1992 ACURA INTEGRA
  • 4 CYL
  • 150,000 MILES
My daughter was driving down the road when it just shut off and coasted to a stop. She tried to re start it. It turns over, but it does not fire. What should I check?
Saturday, March 13th, 2010 AT 3:05 PM
Get a helper disconnect a spark plug wire or two and ground it to the engine at least 3/16 away from ground -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, distributor pick-up coil, ignition control module, cam and crank sensors and computer.
Tuesday, January 24th, 2017 AT 7:57 PM
