1992 Acura Integra Car starts but will not shift into gear
171,000 MILES • 4 CYL • 2WD • MANUAL
TPGTHUG
My car started acting up by slipping when in reverse and 1st. then after sitting for about an hour it starts perfectly in neutral, just changed the starter 2 or 3 weeks ago. once it starts it's fine, until i try to shift into gear. it will not go into 1st or 2nd, only 3rd to reverse and when i get it into gear it stalls out. when the car is off it switches to all gears smoothly, but trying to start in any gear causes the car to violently buck like a horse, turning over as if to start, going forward or backward depending on the gear. the pedal is very stiff compared to the day before, and does not fully engage when i press it. I heard it may be a safety switch, but do not know which to check. I know of one above the clutch pedal and one that is supposed to be by the shifter under the center console. if it is under the console, how do i locate that switch? are they simple switches to go off on position or will it be a more technical job of repllacement and things of the such?
Nov 26, 2009 at 1:18 AM
MERLIN2021
  • 17,250 POSTS
The neutral saftey is either misadjusted or shorted, but even so, with the clutch depressed, the car should not move while cranking, it will move if NSS ibad and clutch isnt depressed, but the clutch if depressed and car moves, is NG as well.
Nov 26, 2009 at 1:35 AM
TPGTHUG
not sure what NG means and it moves while compressing clutch and starting unless it is in neutral. if i am not pressing the clutch and it moves it is NG and NSS?
Nov 26, 2009 at 1:49 AM
MERLIN2021
  • 17,250 POSTS
If clutch is depressed and the car moves or lurches like under power by the starter, the the clutch is NG(No Good)! NSS(neutral saftey switch).
Nov 26, 2009 at 2:10 AM
TPGTHUG
ok thank you, it only does the moving with clutch compressed while starting the car in any gear besides neutral.
Nov 26, 2009 at 2:20 AM
KHLOW2008
  • 41,812 POSTS
From the symptoms described, you have a bad clutch disc or the clutch hydraulic system is faulty.
Check the hydraulic system first and if ok, then the clutch needs to be disasembled to check the cause.
Nov 26, 2009 at 4:35 PM
