90 Acura Integra 189K miles manual trans shift problems
CARLIFE65
  • 1990 ACURA INTEGRA
Sound like yuor clutch disc, is bad, or transmission shift linkage, loose or worn shifting linkage.
Thursday, October 22nd, 2009 AT 9:11 PM
RDB1025
My integra has problems going into gear after exiting the freeway after driving 70 MPH and over. The problem persists for 5 to 10 minutes and then the car shifts fine. The problem will also happen intermittently during town driving. The clutch has 25k Miles. The manual gearbox fluid was also changed with the clutch and it does not leak. There is a lot of slop in the shift handle. Can the play in the linkage and bushings up to the gearbox cause this problem. Thanks for any advice, I hope to keep the car on the road for a few more years v/r Rick
Sunday, January 28th, 2007 AT 5:47 PM
CARLIFE65
  • 200 POSTS
