1990 Acura Integra Should I get an second opinion for A/
1990 ACURA INTEGRA
ACURAINTEGRA90
Air Conditioning problem
1990 Acura Integra 4 cyl Front Wheel Drive Automatic
I took my car in for free a/c inspection with brake job...but mine had the old system and they need to charge me $140 to install the new fittings and charge system, plus add a green dye to see where it's leaking.
For the first few days after getting this service the a/c was ice cold and never made any noticeable weird noises. On day 3 it was blowing hot again and I checked under the hood and found a large leak in the upper house that is above the radiator. That's also where I noticed the green dye. I looked over the engine and didn't see any more dye. So I took it back in and asked them to fix the leak and recharge the system.
They supposedly tested it all out and looked at the compressor and evaporator with a black light or something and saw leaks everywhere.
I question whether I may really need the whole system replaced after it was super cold for 2 days and I heard no strange noises and only noticed one leak. I also question a compressor leaking but working perfectly when the system was fully charged...
Also do the prices sound high?
They said I need to replace:
Rec Suction hose assbly repair $139.99
Discharge hose assbly repair $169.99
Reman Compressor $319.99
Rec. R134a $24.99
O-Ring kit $34.99
Expansion Valve $59.99
Rec A/C Flush NC with repairs
Labor $253.00
15% Discount off labor
Total $1002.94
Total with discount $964.99
Thank you very much!
Jun 29, 2009 at 11:22 AM
MERLIN2021
  • 17,250 POSTS
Whenever the bill is that high, a second opinion doesnt hurt, you see the main leak, everyone does if it's big enough, the sell a flashlight with an amber colored plastic shield attached to see the smaller stuff, it costs about 25.00 dollars, if you want to satisfy your curiousity!
Jun 29, 2009 at 11:26 AM
