1989 Acura Integra Engine oil Light ON and Temperature disp
1989 ACURA INTEGRA
220,000 MILES • 4 CYL • FWD • MANUAL
WOONSOCKET_KENNYG
Hi, my Engine oil light is on and the temperature shows in highest when i switch the key to power. the other thing is that i didn't drive the car for days and this situation still occur. i am wonder that should i go to oil change to try it may be back to normal (but oil is full and moderate dark and coolant is full too). Or, there is some other issues actully happening to the car. The fact is that i don't drive the car that much, may be 2 miles per week, and i just want to keep it until i am able to rebuild the car.
Thanks for help and i look forward to you
Kenny
Mar 21, 2009 at 2:55 PM
KHLOW2008
  • 41,814 POSTS
Hi Kenny,
Does the temp gauge shows high even when engine is cold?
After starting, the engine oil light does not go off? Does revving up the engine make the oil light goes off?
Mar 22, 2009 at 9:49 AM
