1997 Acura CL High Clutch Engagement
ASO333
  • 6 POSTS
I noticed that the clutch engagement on my car seems to be on the high side. Is this an indication that the clutch is worn and will soon need replacement. It still shifts fine and smooth. My car has high mileage, but the clutch was replaced about 35,000 miles ago my driving habits have not changed. It is a 97 Acura CL 2.2 with 197,000 miles.
Sep 14, 2007 at 4:15 AM
BRUCE HUNT
  • 3,754 POSTS
Not really, but it might indicate a beginning failure in the hydraulics of the clutch master or slave. I would watch it closely. There is no adjustment of the clutch pedal.
Sep 15, 2007 at 11:08 AM
Suggested Repair
High clutch engagement is not necessarily a worn clutch. Watch it closely for early hydraulic failure in the clutch master or slave cylinder. The clutch pedal has no adjustment.
Conversation Summary
The owner of a high-mileage 1997 Acura CL 2.2 noticed high clutch engagement and asked whether the clutch, replaced about 35,000 miles earlier, was worn. Shifting remained smooth. The expert said this does not necessarily mean the clutch is worn, but it may indicate beginning failure of the clutch master or slave hydraulics, so it should be watched closely. There is no clutch pedal adjustment.
