1999 Acura CL Gear Shift Stuck in Park
EYBROWN
  • 6 POSTS
1999 Acura CL 3.0; V6, 152,000 miles
I cannot press the button to allow my gear shift to release out of park. Recently, my brake light has been on & off when I drive, but I have had my brakes serviced. Could the brake sensor light be the problem?
Aug 6, 2007 at 6:05 AM
BRUCE HUNT
  • 3,754 POSTS
When it is very quiet you should be able to hear release of the shifter as the brake is applied. Either the switch at the brake pedal is out or the solenoid at the shifter.
Aug 6, 2007 at 6:48 AM
EYBROWN
  • 6 POSTS
I can not hear it. I can only hear it when it is working. Forgive me, but what is the solenoid?
Thanks for the quick response.
[quote:770bde0b89="Bruce Hunt"]When it is very quiet you should be able to hear release of the shifter as the brake is applied. Either the switch at the brake pedal is out or the solenoid at the shifter.[/quote:770bde0b89]
Aug 6, 2007 at 6:57 AM
Suggested Repair
Check the brake pedal switch and the shift-lock solenoid at the shifter. An absent release click when the brake is applied points to one of those parts.
Conversation Summary
The owner of a 1999 Acura CL cannot release the shifter from park and has an intermittent brake light despite recent brake service. The expert says a quiet release click should be heard when the brake is applied and that either the brake pedal switch or the shifter solenoid is faulty. The owner cannot hear the click and asks what the solenoid is; no further reply is given.
