Car is suddenly misfiring on 4 cylinders. Codes P1739, P1399 Prob cause 01 Blocked EGR passage Prob cause 02 valve clearance out of range, P0300 Random cylinder misfire detected Prob cause 01 fuel system concern prob cause 02 ignition system concern Prob cause 03 MAF sensor faulity Prob cause 04 H02S/AF (heated oxgen sensor/Air-Fuel) ratio sensor fault Prob cause 05 Blocked intake or exhaust system, Cylinders 2,3,4,5 P0302 P0303 P0304 P0305 all have Prob cause 01 Vacuum leak affecting one cyclinders Prob cause 02 Ignition system concern Prob cause 03 Blocked/faulity fuel injector Prob cause 04 Engine machanical condition
Where do I start?
Where do I start?
May 4, 2010 at 2:48 PM
