1997 Acura CL Tranmission skipping
1997 ACURA CL
115,000 MILES • 6 CYL • 2WD • AUTOMATIC
SIGNATURE WINES
After driving on the freeway (usually, although sometimes on a city road), when I exit and stop at the bottom of the exit, when I attempt to go forward, the RPMs will go up, there is a hesitation for a second or two but the car will not go forward immediately. Is this a common problem? What needs to be done to fix the problem?
Jun 1, 2008 at 11:51 AM
KHLOW2008
  • 41,814 POSTS
Hi Signature Wines,
Looks like you have some slippage with the clutches.
It might be as simple as not enough ATF or the ATF need replacement to a trans that is about to give way.
Check the basics first.
I am not sure what variant of trans is used but if it comes with a trans throttle cable, then some adjustment might solve the problem.
Jun 2, 2008 at 1:47 AM
