1998 Acura CL
AMYERS2
  • 1998 ACURA CL
  • 4 CYL
  • FWD
  • MANUAL
  • 162,000 MILES
I have a 5 speed and it is difficult to shift gears. The clutch seems loose, and it is difficult to put it in gear
Saturday, May 29th, 2010 AT 4:07 PM
KHLOW2008
  • 41,814 POSTS
Hi amyers2,
If the clutch is loose, then it most probably is not providing sufficient travel of the clutch bearing to release the cluch and ensure easy smooth gear shifting.
Check the clutch fluid level.
Sunday, May 30th, 2010 AT 9:46 AM
