Acceleration problem
50,000 MILES • 1.5L • 4 CYL • 2WD
ABDULLAH AL MAMUN
My car listed above is a Fielder model second generation with CVT. Problem is when initial acceleration I feel no power at 1,500 rpm's, my behind car overtake me. But after few seconds car is going fast to reach 100km at 2,000 rpm's. CVT fluid change 1 month back. Now what can I do how can I produce power at initial acceleration?
May 1, 2020 at 5:54 AM
  • 110,248 POSTS
Does it seem as though the transmission is slipping or anything like that? If not, is the check engine light staying on when the engine is running?
When I hear power loss, the first thing I suspect are low fuel pressure or a partially plugged catalytic converter. Has any of that been checked? Also, once you get up to speed, does it run normally?
If the check engine light stays on with the engine running, you need to scan the computer for diagnostic trouble codes. Here is a quick video showing how it's done:
https://youtu.be/YV3TRZwer8k
I realize not everyone has a scanner, but often times, a parts store will scan it for you at no charge.
Next, take a look through this link. It explains the common symptoms of a catalytic converter issue. See if the things discussed mirror what you experience.
https://www.2carpros.com/articles/bad-catalytic-converter-symptoms
Here is a link which explains how one is tested:
https://www.2carpros.com/articles/how-to-test-a-catalytic-converter
One last thing is fuel pressure. Here is a link that explains how in general it is tested:
May 1, 2020 at 12:15 PM
