When I put the transmission in gear it will not accelerate
280,000 MILES
CASEYHELMS
Okay, so the car will dial fine and it will rev up if it is in park or neutral, however when I put the car in gear it will not accelerate. If it’s on a hill and is facing down it it will slowly begin to accelerate and once it gets over 1,000 or so it’s fine and will run and drive all day until you come to a complete stop then the problem starts all over. I have replaced plugs wires and it didn’t change the problem. Any help would be great it’s my wife’s only car and I’m lost on what to do!
Apr 18, 2019 at 2:06 AM
  • 55,721 POSTS
It sounds like you are having an issue with eh PCM. To be sure lets run the codes here is a guide to help us get started:
Apr 19, 2019 at 5:44 AM
CASEYHELMS
I don’t have access to a scan tool at the moment any other ways to check that or possibly other things that it could be. Could it be a vacuum leak or possibly a fuel mixture problem?
Apr 21, 2019 at 3:29 AM
  • 55,721 POSTS
Yes is sounds like you have a clogged catalytic converter. here are two guides to help us see what is going on:
https://www.2carpros.com/articles/engine-has-low-power-output
and
https://www.2carpros.com/articles/how-to-test-a-catalytic-converter
Apr 22, 2019 at 6:40 AM
