accessory mode will not shut off
36,000 MILES
MICHELLE HOPE
My radio stays pm after I open the door. It also drains my battery down. I have removed the fuse for the radio and it has been okay, but I am driving without a radio through. I believe it is stuck in accessory mode. How do I turn the accessory mode of some I can listen to my radio again without having to remove the fuse when I get out the car to insure my battery will not be drained when I go to crank it back up?
Feb 9, 2017 at 9:53 PM
HMAC300
  • 48,601 POSTS
there are four different radios and each are powered differently. have a mechanic scan for codes to see if it is a module that powers the fuse that is the problem or if it is radio.
Feb 9, 2017 at 11:15 PM
