AC recharge
125,000 MILES • 3.1L • 2WD • AUTOMATIC
EGUNS80
  • 85 POSTS
We have a Robinair 34288 machine at work, I want to recharge my AC and have a few questions. First question is, can you tell me how much refrigerant I am supposed to fill my system to? My second question is, do I refill through high pressure line, low pressure line, or both?
Jul 14, 2018 at 7:30 AM
Good afternoon.
You need 2.2 lbs of Freon.
Vacuum it for at least thirty minutes, then with the engine off charge it from both sides. You never charge the system from the high side with the engine running. If you do, it will fail the compressor.
Jul 14, 2018 at 7:36 AM
