AC problem
200,000 MILES • 6 CYL • 2WD • AUTOMATIC
DANNY BLACKBURN
  • 11 POSTS
AC was working good after I charged it. It's been parked and I checked it four days later and compressor won't come on I thought it might have a leak so I put gauges on and it has a lot of pressure like the high side.
Jun 5, 2019 at 4:14 AM
  • 110,248 POSTS
Welcome to 2CarPros.
If the compressor isn't engaging, it could be low on Freon or the clutch may be faulty. Have you checked to see if power is being sent to the compressor? You mentioned the high side pressure. Can you tell me both low and hi side pressures and the outside temperatures when tested?
Also, here is a link for you to look through related to the AC not working. You may find them helpful. Let me know if you find anything that seems to mirror what you are experiencing.
I will watch for your response.
Jun 5, 2019 at 2:18 PM
DANNY BLACKBURN
  • 11 POSTS
I'm going to check and see if compressor is getting power tomorrow and that should tell me where to start looking. Thanks I'll let you know.
Jun 5, 2019 at 2:37 PM
  • 110,248 POSTS
Sounds like a plan. I will watch for your reply.
Good luck and take care,
Jun 5, 2019 at 2:40 PM
DANNY BLACKBURN
  • 11 POSTS
I couldn't get the air compressor plug off to check volts. I pulled plug off dryer bottle and it had four wires and I didn't know how to cross the wires to make compressor come on so I put it back on. I tried the A/C again and it was working. I put Freon back in it because I let some out before and it spitting snow balls at me now. Lol. Must of lost connection at that plug. Anyway, thanks.
Jun 5, 2019 at 11:40 PM
  • 110,248 POSTS
Welcome back:
So it's working now? If so, it must have been like you said, a bad connection.
Jun 6, 2019 at 11:48 AM
DANNY BLACKBURN
  • 11 POSTS
Still working great. It had to be a bad connection at the plug.
Jun 6, 2019 at 2:08 PM
  • 110,248 POSTS
Danny:
Yep, that's it. I'm glad you got it fixed. Let us know if you have questions in the future.
Take care and have a great weekend.
Jun 7, 2019 at 11:06 AM
DANNY BLACKBURN
  • 11 POSTS
You too and thanks.
Jun 7, 2019 at 12:02 PM
  • 110,248 POSTS
Happy to help.
Jun 7, 2019 at 3:54 PM
