A/C not cooling?
IHATEKIA
  • 2000 KIA SPORTAGE
  • 4 CYL
  • 4WD
  • 86,000 MILES
Originally when turning on the A/C or heating in my car it would make a noise. Like the fan had some issues or something. But the noise always stopped after a minute or so. NOW, of course with summer arriving, I am getting nothing. No more noise, no more air coming through of any sorts- hot or cold. My guess is it has either something to do with a motor or a fan or who knows. I know nothing about cars and just need to know where to start on this issue!
Thursday, April 9th, 2020 AT 12:02 PM (Merged)
DAVE H
  • 13,384 POSTS
Check blower motor fuse in passenger compartment fuse box. Check the resistor located on blower motor housing and check wiring, and the actual blower motor. I suspect the motor needs replacing from your description of the fault !
JILLSTL
  • 2006 KIA SPORTAGE
  • 6 CYL
  • 75,000 MILES
I have noticed that after about an hour of driving, the AC slowly starts to get warm. At first it works great, it is so cold I have to have the blower on low and slowly I will turn the blower up to full speed and it is still warm. My temperature gauge on my dashboard never moves to indicate that my car is overheating. Why does my AC get warm after an hour of driving?
Could be no/low freon, compressor, or the air blend door is sticking or the air blend door motor itself malfunctioning
PENIX36
  • 2006 KIA SPORTAGE
  • 2.5L
  • V6
  • 4WD
  • 140,000 MILES
I have noticed that after about thirty minutes of driving, the AC slowly starts to get warm. At first it works great, but after driving a while it turns warm. My temperature gauge on my dashboard never moves to indicate that my car is overheating. It has Freon. Thanks
  • 31,937 POSTS
Refrigerant charge may be low or over full, this need to be tested with a A/C charge unit. The correct level is critical and also a blocked condenser can also be a problem. Flush through the condenser to make sure air flow is not interrupted with leaf litter, bugs or mud build up.
HOOKIE
  • 79 POSTS
  • 1998 KIA SPORTAGE
Air Conditioning problem
1998 Kia Sportage 4 cyl Two Wheel Drive Automatic
lOW SIDE =40 PSI
HIGH SIDE=240 PSI
outside temp (FLORIDA)=92 degrees (F)
topped freon off since it was not blowing cold at all; pressures read as above with blower on HIGH.
THE low side ac pipe coming out of engine firewall(evaporator) is warm, other high side pie (ac line ) is HOT to touch. What could be worng. BOTH fans come on (ac condensor and radiator fan. Car NOt overheating).
Problem seems intermittent. Sometimes car will blow cold air (only when pipe coming out of evaporator(low side is cool to touch and sweating; otherwise, pipe gets hot again and will not cool car.
Both fans(AC CONDENSOR and radiator fan turn on). Car not overheating. PLEASE advise, thanks
Thursday, April 9th, 2020 AT 12:03 PM (Merged)
DOCFIXIT
  • 18,828 POSTS
Try fan on low doors, widows closed does low go down say to 30psi? And system blow cool? If not check temp. Blend door cable may have bent if not closing then heater coer is warming air.
DTDODD
  • 24 POSTS
  • 1997 KIA SPORTAGE
  • 108,000 MILES
When the car is running and the a/c is turned on it blows cold for about 10 min then switches to just normal air temp. Could this be the compressor?
Any other ideas?
If the compressor is there any issue with me changing it then having a tech evacuate the system pressure test and fill with freon?
Thanks
SATURNTECH9
  • 30,869 POSTS
It could be a lot of things like compressor condensor fan inop car overheating debris in radiator or ac condesor fins blocking air flow low on charge. Without actually checking high and low pressures ac condensor fan operation one would only be guessing as to why it does that.
