A/C stopped blowing cold air
2009 GMC ACADIA
154,000 MILES • VR6 • 2WD • AUTOMATIC
KLOEYSPIVEY
i noticed the vents in the back seat weren't blowing as cold and little by little it stopped being cold and not too soon after that the front vents stopped blowing cold as well. My first thought was to recharge it/check for Freon leaks. After doing so, i didn't find any leaks and after recharging it, it was cold so i thought problem solved but after driving it for about a day, the A/C started blowing warm again. I was told to pull out the compressor relay clutch fuse, as well as taking out the HVAC fuse for 10 seconds but that also didn't.
Aug 14, 2021 at 10:24 PM
  • 110,244 POSTS
You must have a leak at some point. I don't know what procedure you used to check for leaks, but take a look through this link. It explains how to locate a leak.
https://www.2carpros.com/articles/air-conditioner-leak-detection
Let me know if that helps or if you have other questions.
Aug 15, 2021 at 2:41 PM
