A/C not blowing cold air
135,000 MILES
TONY02
  • 86 POSTS
The A/C doesn’t blow cold, the compressor is engaging, and I hooked up my gauges to make sure there is refrigerant in it and there is, but it’s not blowing cold. I also felt the low-pressure line and it doesn’t feel cold or isn’t “sweating” like it should be it’s just dry.
Jun 12, 2022 at 8:57 AM
BORIS K
  • 836 POSTS
As you have gauges can you please confirm the system pressure when A/C is switched off and low/high pressure when system is operating.
Also is the cooling fan operating when the A/C is switched on?
Cheers, Boris
Jun 12, 2022 at 7:03 PM
TONY02
  • 86 POSTS
The low side is around 50-60 and the high side was around 150-200. Yes, the cooling fans are working, but I also notice that the compressor clutch stays on it does not disengage.
Jun 12, 2022 at 8:27 PM
BORIS K
  • 836 POSTS
The low-pressure side looks a bit high, you should have about half, 26-36 PSI at 1500 RPMs.
The high pressure is also a bit low, expect to see 225-250 PSI.
You either have too little refrigerant or a possible faulty expansion valve.
Cheers, Boris
Jun 12, 2022 at 11:42 PM
TONY02
  • 86 POSTS
Upon looking for expansion valve I found the evaporator core with it, and it was really filthy and dirty. My guess is the evaporator core from being dirty was giving me the issue.
Jun 15, 2022 at 11:12 AM
BORIS K
  • 836 POSTS
It does sound plausible that this is cause of the air-conditioning not blowing cold .
Please keep us posted on the outcome
Cheers, Boris
Jun 16, 2022 at 10:39 PM
