AC is not cooling?
SINBAD271
  • 169 POSTS
Is your a/c compressor clutch spinning while vehicle is running and a/c switched to on?
Thursday, December 17th, 2020 AT 11:43 AM (Merged)
YMCDANIEL77
I do not know. What I do know is only one of those sm. Ac. Fans are working. Ive watched video of how to replace the ac. Blower Motor Switch.(. Seems workable for me. And since its in the same area. Where the kids ripped not only my Bumpg stereo out of my dash.I'm thinkg they disconnected. Cut. Fried or. Disabled. That Blwr Mtr Swtch.I know the cig lighter didn't wrkr after that. Also. Could a blown ac fuse. Cause one fan not to work. Are they connected by a fan belt of sorts
SINBAD271
  • 169 POSTS
When blower motor turned on does any type of air blows out of the vent hot or cold?
CHRISTOPHERJ
  • 1996 HONDA ACCORD
  • 4 CYL
  • FWD
  • 105,000 MILES
I've taken my 96 accord to my honda dealer a few times now because it seems like the air just isn't cold enough but they tell me everything is fine with it and the air is blowing cold "within range" whatever that means. However, my 97 4runner gets ice cold no matter how hot it is outside so why can't this Honda get at least colder? I had a friend who has a Pontiac vibe and he found out that his lever on his dash thermostat as another adjust below near the floor and when he adjusted that the air immediately blew colder, the cold low end setting was just off. I'm wondering if Honda's have the same type of adjustment I could do? Thanks for the advice in advance! - ChristopherJ
Thursday, December 17th, 2020 AT 11:44 AM (Merged)
KHLOW2008
  • 41,814 POSTS
Hi Christopher.
If the heater air mix door is not closed fully, the A/C cooling owuld be affected.
AIR MIX CABLE
At air mix door linkage (bottom right side of heater case), disengage cable housing from clamp and disconnect cable wire from control arm. At heater control panel, select maximum cool position and hold it in this position. At air mix door linkage, reconnect cable wire to control arm. Gently slide cable housing back to eliminate slack, then snap cable housing into clamp. Adjust heater valve cable.
HEATER (COOLANT) VALVE CABLE
1. At heater valve (center of engine compartment firewall), disengage cable housing from clamp and disconnect cable wire from heater valve. At air mix door linkage (bottom right side of heater case), disengage cable housing from clamp and disconnect heater valve cable wire from control arm.
2. At control panel, set temperature control to maximum cool position and hold it in this position. At air mix door linkage, connect cable wire to control arm. Gently slide cable housing back from control arm to eliminate slack, then snap cable housing into clamp.
3. At engine compartment firewall, keep heater valve closed. Connect cable wire to heater valve, gently slide cable housing back from heater valve to eliminate slack, and then snap cable housing into clamp.
