HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Dodge
Caravan
Climate Control
Heater
Not Working
SPONSORED LINKS
No heater operation?
PREV
1
2
NEXT
MECHANIC
Thanks for using 2Carpros let us know if you have other questions.
Monday, November 2nd, 2020 AT 7:53 AM (Merged)
PREV
1
2
NEXT
Please
login
or
register
to post a reply.
Related Heater Not Working Content
Heater Not Working?
I Have No Heat In The Front Cabin Of My Van. However, The Rear Compartment Does Get Heat. What Causes All Of This? Is It A Costly Fix? Or...
Asked by
jcmjbmld
10 IMAGES
2003
DODGE CARAVAN
VIDEO
Heater Not Working
Instructional repair video
GUIDE
Heater Not Working
Step 1 - A heater cannot operate unless the engine is full of coolant/antifreeze. If coolant level is low check the system for leaks.
Heater Not Working?
My Sister-in-law Has A Dodge Caravan. The Heat Only Works On The Driver"s Side. It Is Luke Warm At Best. Passanger Side Is Cold. It Has...
Asked by
jshuffman
3 IMAGES
1999
DODGE CARAVAN
My Heater Is Not Working Why?
My Van Is Overheating Very Quick After Starting And There Is No Heat. I Have No Coolant Leaks And Just Replaced Thermostat.
Asked by
garkel34
3 IMAGES
2001
DODGE CARAVAN
No Heat
No Heat In A 2000 Grand Caravan--3.8--pass. Zone Temp. Rear Heat. Programmable Control Panel. Flushed Core-didn't Help. Replaced Core And...
Asked by
jerrb
1 ANSWER
2000
DODGE CARAVAN
Heater Problem
Heater Puts Out Heat When First Turned On Then Goes Cold And The Water Level Is Full.
Asked by
Harry Elliott
2006
DODGE CARAVAN
VIEW MORE
SPONSORED LINKS
Heater Not Working
How to Replace Damper Door Switch
Blend Door Actuator Replacement
Online car repair manuals
