AC does not blow cool air
200,000 MILES • 5.4L • V8 • 4WD • AUTOMATIC
PACKERS27
  • 207 POSTS
My AC does not blow cool air out the vents either. If I drive about two miles down the road, stop and put it in park then I can tell it is gone when I rev the engine. The AC will start blowing cool air then. It only does this when the truck is cooled off. I can crank up the truck in the morning and let it idle for as long as I want to and it does not matter. I have to drive it a couple miles and put it in park before the rough idle and jerking is gone. Then my AC works again immediately. Is there a common link between the AC and what could be wrong? Thanks
Aug 28, 2018 at 6:09 AM
  • 55,746 POSTS
Please one problem at a time, please start a new question for your idle issue. We will handle the AC on this thread. It sounds like the system is low on charge. Here is a guide to help confirm and fix the issue: Sometimes the computer will shut down the A/C if the engine is misfiring to take load off it. Scan for misfire codes, may just need a tune up
https://youtu.be/uZrQCGwXfek
Cheers, Ken
Apr 15, 2021 at 7:44 AM
