A/C compressor is off, how you reset it from the inside?
175,940 MILES • 4.8L • V8 • 2WD • AUTOMATIC
TODD GRADY
A/C won't come on,says on the dash ac off low coolant.can it be reset from the inside of the car?
Jun 15, 2021 at 10:46 AM
Can you get a picture of the warning message that you are seeing?
I am not familiar with one that says the A/C is off due to low coolant. However, these messages cannot be reset. The issue needs to be corrected and the sensor will turn the light off.
However, if the AC is shut off due to the low coolant then we need to check the coolant level and make sure it is full.
If it is full then you may have a sensor issue where it thinks the coolant is low when it is not.
Here are some guides that will help with this:
https://www.2carpros.com/articles/radiator-pressure-test
https://www.2carpros.com/articles/car-is-leaking-coolant
Please let us know if you can get some pictures of this and we can go from there. Thanks
Jun 16, 2021 at 11:45 AM
