AC oil
120,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
ZEMORZEMOR
  • 486 POSTS
The A/C was evacuated before timing belt replacement. How much oil do I need to add before refill it. What kind of oil and are there any a/C parts needs to be replaced?
Thank you
May 20, 2018 at 5:16 AM
Good afternoon.
When the Freon was recovered, how much oil was recovered?
I suggest replacing the receiver/dryer assembly since the system was open to outside air.
I would add two ounces of oil to the system if you replace the dryer.
Use Pag 100 oil.
Why did they remove the compressor?
I have never removed the compressor in the dozens of timing belts I have replaced on this model?
https://www.2carpros.com/articles/re-charge-an-air-conditioner-system
https://www.2carpros.com/articles/air-conditioner-how-to-add-freon
May 20, 2018 at 6:11 AM
ZEMORZEMOR
  • 486 POSTS
So do I have to replace the dryer? I did not removed the compressor. I do not know how much oil was recovered.
May 20, 2018 at 6:49 AM
If the lines were opened, then yes. Once outside air gets into the system, it contaminates the bag in the dryer.
May 20, 2018 at 6:57 AM
ZEMORZEMOR
  • 486 POSTS
So replace dryer and add two ounces of oil.
May 20, 2018 at 7:03 AM
Correct. The two ounces is for the new dryer.
May 20, 2018 at 7:05 AM
ZEMORZEMOR
  • 486 POSTS
How much oil you think came out when A/C was evacuated? How much need to add in additional of the two ounces for the dryer.
May 20, 2018 at 7:07 AM
Only the person who recovered the Freon can tell you. If they used a machine, as they should have, they should see the oil in the tank that was recovered.
Generally, there is little or no oil recovered but every system is different.
May 20, 2018 at 7:12 AM
ZEMORZEMOR
  • 486 POSTS
The other thing how to add the two ounces of oil?
May 20, 2018 at 7:38 AM
It is done through the machine that is doing the evacuation and charge or you will need an oil kit from a parts store. It looks like a caulking gun and attaches to the oil bottle. You will inject it into the system after you vacuum it for forty minutes, add the Freon after you add the oil.
May 20, 2018 at 7:51 AM
ZEMORZEMOR
  • 486 POSTS
Under the hood it says refrigerant 1.125 LB is this the max charge ? Is there another way to inject oil beside using the tool?
May 25, 2018 at 12:05 PM
That is the exact amount of Freon that needs to be added for the system to work correctly.
No, there is not. You need that tool. A parts store will have this for you.
May 26, 2018 at 5:06 AM
ZEMORZEMOR
  • 486 POSTS
At Walmart they have A/C Pro r134 pag oil charge with ice 32 performance enhancer. It is in compressed can of 3 oz 1 oz oil 1 oz pag 100 1 oz ice 32. Can I use two cans of those instead to use the tool which is expensive for my budget?
May 27, 2018 at 3:11 AM
No, use 134. substitute Freon do not work well at all.
Pag oil is good.
May 27, 2018 at 3:15 AM
ZEMORZEMOR
  • 486 POSTS
Okay, I think you misunderstood, sorry.
At Walmart they have Pag 100 oil in compressed can of 3 oz. In one can there are 1 oz of R134, 1 oz pag 100 and 1 oz of ice 32 performance enhancer . Can I use two cans of those instead to use the tool to inject oil which is expensive for my budget? After I will add 16 Oz of R134.
May 27, 2018 at 3:46 AM
Okay, sorry.
Do not use the performance enhancer, just the 134 with oil.
May 27, 2018 at 3:50 AM
ZEMORZEMOR
  • 486 POSTS
Okay, thank you.
May 27, 2018 at 3:52 AM
You are welcome. Keep us updated.
May 27, 2018 at 3:56 AM
ZEMORZEMOR
  • 486 POSTS
I want to add some UV dye. What is the quantity needs to be added and what kind?
Thanks
May 29, 2018 at 12:33 AM
If you are using cans to fill the system, just add one can with UV dye.
May 29, 2018 at 12:39 AM
ZEMORZEMOR
  • 486 POSTS
Yes I am going to use cans. Which I have already purchase without UV on them.
May 29, 2018 at 2:23 AM
Okay, you can return one and replace it with one with UV.
Easy to do that.
May 29, 2018 at 2:26 AM
ZEMORZEMOR
  • 486 POSTS
Okay, I replaced the accumulator drier. Vacuumed the system for half an hour and check for leak for two hours. No leaks after I vacuumed it again for an hour and a half. I added Freon the first can went great the second can I should add from it six ounces. The scale I bought turned off when I was adding Freon. I think I put six ounces from it. However, what I noticed after at idle the compressor kept running and the temperature was 50 degrees. When I drove the car the temperature went down to 40 at max AC aka re-circulation went down to 37.
Jun 3, 2018 at 10:02 AM
Okay, sounds good.
Do you have a concern? It sounds like it is working good.
Jun 3, 2018 at 10:06 AM
ZEMORZEMOR
  • 486 POSTS
Should the compressor cycle at idle? It was cycling when I was adding the first can but after that when adding the second it ran continually. What about the temperature at idle is it normal?
Jun 3, 2018 at 10:08 AM
The compressor cycled due to Freon level low. Once you filled the system it will stay running.
The temperature is good at idle. Even better while moving.
What was the high side and low side pressures at idle?
Jun 3, 2018 at 10:10 AM
ZEMORZEMOR
  • 486 POSTS
At idle high side was between 250 and 275 and low side above 50 around 53.
Jun 3, 2018 at 10:55 AM
A bit high but good. Did you make sure the radiator and condenser fins are clear of any dirt and debris and you have good air flow from the fan?
Jun 3, 2018 at 11:01 AM
ZEMORZEMOR
  • 486 POSTS
Yes, I cleaned the condenser when I did the timing belt. So should the compressor cycle or not?
Jun 3, 2018 at 11:03 AM
Nope, there is no need with the readings you have.
In my opinion, you are good to go.
Jun 3, 2018 at 11:12 AM
ZEMORZEMOR
  • 486 POSTS
I will clean the condenser again and straighten the fins. The other thing is I had problem with the fan it was not engaging and the car was overheating. The problem was the fan connector was sparking and burn out. I just tighten the pins.
Jun 3, 2018 at 11:15 AM
Okay.
I would get a new pig tail for the connector and replace it.
Jun 3, 2018 at 11:18 AM
ZEMORZEMOR
  • 486 POSTS
Today I cleaned the condenser and straighten the fins. Temperature is the same. Also I checked the fan operation. There are two relay's on the top of the fan. When I jumped the first one the fan run. When I jumped the second one the fan ran with the same speed. I heard this car has two speed fan? Low and high. How the computer command the high speed fan?
Jun 5, 2018 at 4:56 AM
The TIPM or the fuse box controls the high speed fan. The dark blue/orange wire should be hot to run the fan at high speed. If that wire is hot or has voltage, the fan itself is the failure.
Jun 5, 2018 at 6:02 AM
ZEMORZEMOR
  • 486 POSTS
The compressor making little noise when initially turn the AC on. After few seconds goes away.
Jun 8, 2018 at 1:11 AM
Okay, that sounds like the compressor is low in oil. That oil is separate from the Freon system. In order to check this, the compressor will need to be removed and the oil drained. Compare that to what the spec is for the compressor. Add as necessary.
If you do not do this, the compressor will fail.
The spec is 5.5 ounces of oil.
Jun 8, 2018 at 4:28 AM
ZEMORZEMOR
  • 486 POSTS
So I need to drain and add 5.5 oil to the compressor. Do I need to consider the oil left in the lines, accumulator. etc?
Jun 8, 2018 at 6:28 AM
No, separate system for oil.
When you recover the Freon, there should be little or no oil recovered from the Freon system.
Jun 8, 2018 at 6:32 AM
ZEMORZEMOR
  • 486 POSTS
So what I need to do is to remove compressor,empty it from its oil, put 5.5 oz oil in it and do not worry about the oil left in the other parts?
Jun 8, 2018 at 6:58 AM
That is correct.
Jun 8, 2018 at 8:02 AM
ZEMORZEMOR
  • 486 POSTS
I am confused sorry.
I did some recherche I found out:
Total system capacity 6.1 oz.
Filter drier 1.0 oz.
Condenser 1.0 oz.
Evaporator 2.0 oz.
All refrigerant line 1.5 oz.
If i put 5.5 oz in compressor the system will have 10.5 oz of oil which is too much.
Jun 14, 2018 at 1:27 AM
