A/C compressor does not cycle on and off
149,000 MILES
BRIANKLLY22
I hear my compressor turn on when I turn the A/C on, but that is all I hear. It does not cycle from on and off like normal. I thought it needed a charge and went to charge like normal but it is not accepting family refrigerate at all. What could this be?
Mar 14, 2018 at 11:52 AM
  • 31,937 POSTS
you need to vacuum down the system and make sure that it is holding a vacuum. if that is okay, you should be able to charge the system through the low pressure port with the correct weight of refrigerant. if your system is not holding a vacuum, you need to do a leak test and repair fault as required.
Mar 14, 2018 at 6:43 PM
