ABS VSC traction control light flashing
195 MILES • 5.7L • V8 • 4WD
JASON RAJCOK
Replaced 2 front hubs 2 front axles and 2 front speed sensors. Right front speed sensor still coming up as code! Also truck has had issue it rolled on me or sometimes I get in start try to reverse 4lo will beep and I have to put in neutral to engage and let beeping go away then I can go in reverse and other gears.
Jan 25, 2021 at 8:16 AM
What was the specific code that you are getting on the speed sensor?
Here are a couple guides that will help with getting this information:
https://www.youtube.com/watch?v=rTtAnsOlZU4
Also, here is a guide that helps test the wheel speed sensor in the event we need this info:
https://www.2carpros.com/articles/abs-wheel-speed-sensor-test
Lastly, did you replace all this stuff to try and fix this code but it keeps coming up or is this now coming up after you replaced something?
Jan 26, 2021 at 7:11 AM
