What should I use in my cooling system after I replace my water pump
155,724 MILES • 3.5L • V6 • RWD • AUTOMATIC
HUMBLE EMACULATE
  • 13 POSTS
Hey, my car is leaking coolant. when i replace water pump do i pour one gallon of coolant back into my car or should i flush my whole cooling system and fill it back with antifreeze?
Jan 8, 2017 at 11:47 AM
CJ MEDEVAC
  • 11,000 POSTS
If your mix is presently a 50/50 mix of coolant and water (as it should be),
and you lose any amount of it,
All you have to do is top it off with a 50/50 mix from a jug (either bought premixed, or you mix it that way).
That is what is cool about mixing out side of the vehicle.
It does not matter if the vehicle holds a half a gallon or ten gallons, if it is mixed before added, you will always maintain a 50/50 mixture. Even if you top it off later, the mix will always be 50/50.
If you are a 'guesser'- have no idea what the capacity is when empty, and just pour in full strength antifreeze and top it off with water, you will have absolutely no idea what the percentage is in your system.
Draining it all, and mixing fresh outside of the vehicle will insure your mix is correct.
The Medic
Jan 8, 2017 at 12:27 PM
HUMBLE EMACULATE
  • 13 POSTS
Oh okay, thank you. also, when replacing water pump should i replace the thermostat or no because i just replaced that?
Jan 8, 2017 at 12:44 PM
CJ MEDEVAC
  • 11,000 POSTS
If it is relatively new, do not replace it.
I generally go overboard when replacing mine, I replace them once a year just as a precaution, need to or not!
The Medic
Jan 8, 2017 at 12:50 PM
HUMBLE EMACULATE
  • 13 POSTS
Oh okay, because if it was not functioning correctly the check engine light would come on right?
Jan 8, 2017 at 12:55 PM
  • 31,937 POSTS
no, it is not controlled by the PCM, any problem with the thermostat would show on the temperature gauge, stuck closed over heat or stuck open running cold on the gauge, so if it is new, leave it alone.
Jan 8, 2017 at 3:49 PM
