a/c suddenly blows warm air
90,000 MILES
PATCUMMINGS7
My a/c has always been very good, except once when it went from blowing cold to hot fairly suddenly. It turned out that someone had stolen the a/c relay and simply replacing it did the trick. This time I've checked and the relay is still working. I can hear a click near the compressor trying to get it to cycle on, but it doesn't come on. Is there an inline fuse that is blown our something else that may be preventing the compressor from coming on? The belt and pulley are both turning.
Sep 8, 2013 at 6:57 AM
  • 110,251 POSTS
Check to see if there is power to the clutch. If there is, check to see if the system needs recharged. It may be low on freon.
Sep 8, 2013 at 11:13 AM
PATCUMMINGS7
Thanks for the suggestion. I'll try that after work tomorrow.
Sep 8, 2013 at 12:28 PM
  • 110,251 POSTS
let me know what you find.
Sep 9, 2013 at 3:34 AM
