A/C problem
45,000 MILES • 0.5L • 3 CYL • 2WD • AUTOMATIC
ALEXANDER73
My A/C or heater does not work, it does not blow anything out of the vents. I can hear compressor kick on and the fan that cools the engine works and when I switch A/C on the little light comes on showing. it has been turned on but it does not blow out any air out of vents on any level settings for A/C or heater. What can it be? Thanks, Beverly
Jul 3, 2017 at 3:08 PM
JIS001
  • 3,412 POSTS
You would need to see if the blower motor is faulty. If voltage to the blower motor is there then the blower motor is faulty.
Jul 3, 2017 at 7:57 PM
ALEXANDER73
Okay I'll try that then. Thank you very much for responding
Jul 4, 2017 at 4:13 AM
  • 55,770 POSTS
Here is a guide that will help you determine if it is a blower motor problem.
https://www.2carpros.com/articles/blower-fan-motor-works-on-high-speed-only
Please run this test and get back to us we are interested to see what it is.
Cheers, Ken
Jul 5, 2017 at 9:50 AM
