A/C Only Works at Highway Speeds
212,000 MILES • V8 • 4WD • AUTOMATIC
UPMM019
  • 217 POSTS
So I have owned this 2001 Suburban since last October.
To my knowledge the A/C worked fine and had been working fine. However, the drain is clogged and I could never find where to blow it out.
Since the A/C is not working but when I am at highway speeds and have it on after about 10 Minutes the dash makes the suction sound and then the A/C work and she blows cold.
However, once out of highway speeds and in city drive it stops working.
I thought I'd try charging the system but when I hooked up the R-134a setup I have the meter read in the RED which means alert... It did not read low or normal.
Looking to see if anyone has suggestions to the problem.
I did confirm that at idle if you push the A/C on and off the clutch does not engage. However, like I said at highway speeds it works just fine.
Jun 21, 2014 at 4:26 AM
UPMM019
  • 217 POSTS
After letting the vehicle cool down for most of the day I wanted to check it again.
this time when I started the suburban and turned on the A/C it worked and I could hear the clutch engaged but when it did it made a NOT normal noise. Almost a quick squeal of some sort but very very short. it did that a couple of times.
I hooked up the R134a charger again and this time in read in the RED but not as high as before.
I drove it for less than 10 minutes in town and it stopped working again.
Jun 21, 2014 at 9:03 AM
  • 110,251 POSTS
Are you sure that you checked on the low side of the AC system?
Jun 21, 2014 at 1:09 PM
UPMM019
  • 217 POSTS
where is the low side located?
Jun 21, 2014 at 1:25 PM
UPMM019
  • 217 POSTS
If this is the port then, yes, this is the port I hooked my R134a charger too.
Jun 21, 2014 at 1:26 PM
  • 110,251 POSTS
That's correct. If the pressure is too high on the low side, either you have a clog in the system or the compressor itself is bad.
Jun 21, 2014 at 1:36 PM
UPMM019
  • 217 POSTS
can you explain why it works intermittently?
Jun 21, 2014 at 1:37 PM
UPMM019
  • 217 POSTS
would a plugged front A/C drain have anything to do with this?
Jun 21, 2014 at 1:38 PM
  • 110,251 POSTS
The compressor COULD be going bad an causing the pressure on the low side to be too high. Also, the receiver dryer could be bad. Either of these issues could allow the unit to work sometimes and not others. Tell me this. Have you checked static pressure on both the low and high side? That is when the engine is off. Both sides should be nearly equal. When you start the engine, the low side should be around 30 to 35 psi and the high side 210 psi. Are you able to get me a reading with the gauges you have?
Jun 21, 2014 at 1:49 PM
UPMM019
  • 217 POSTS
I could only do the low .
I don't have a manifold set, just the cheapo recharger for the low side.
Jun 21, 2014 at 1:50 PM
UPMM019
  • 217 POSTS
Using the recharger low side, with engine off, it reads around 80psi.
Jun 21, 2014 at 1:55 PM
  • 110,251 POSTS
That is still high. Knowing that leads me to believe the compressor is good and you may have a plugged (or partially plugged) receiver dryer.
Jun 22, 2014 at 1:34 PM
UPMM019
  • 217 POSTS
what would cause it to plug?
This morning the temps were much lower here and I did another reading and this time it showed low so I could add the R134a.
Worked good for two hours straight but then later today it stopped working again.
no strange noises this time.
Jun 22, 2014 at 1:42 PM
  • 110,251 POSTS
Internal contaminates cause issues. As far as it working today, did the compressor stop engaging when it stopped?
Jun 22, 2014 at 2:03 PM
UPMM019
  • 217 POSTS
So the issue continued this past week .... took it to a local shop and today they said it needs a new fan clutch.
Please explain what that has to do with the A/C..... I'm confused....
Jul 1, 2014 at 12:42 AM
UPMM019
  • 217 POSTS
so $175.00 later the shop says it was the fan clutch.
Feel like I was robbed to some degree.....
$99 for a fan clutch
$36 to use the A/C gauges
$38 for labor
plus tax and some other $3 B.S.
Jul 1, 2014 at 5:23 AM
  • 110,251 POSTS
Did that fix it?
Jul 1, 2014 at 11:07 AM
UPMM019
  • 217 POSTS
Well no, in fact it did not.
Same issues as before and I am $175 in the hole from a fan clutch that probably didn't even need to be changed out.
Calling the shop today to complain and hopefully get another appt to have them fix it .... though I don't have high hopes.
Jul 6, 2014 at 10:08 PM
  • 110,251 POSTS
I really didn't think that would do anything. I still feel it is in the receiver dryer. Let me know what you find.
Jul 7, 2014 at 12:56 PM
UPMM019
  • 217 POSTS
Yeah, I think he just quickly changed the fan clutch and didnt check squat after that.
Sorta of BS in my opinion.
Jul 7, 2014 at 2:06 PM
UPMM019
  • 217 POSTS
Why do you think it is the receiver dryer?
Jul 7, 2014 at 10:52 PM
  • 110,251 POSTS
It is the most common item to cause this type of problem. That is just from past experience.
Jul 8, 2014 at 11:43 AM
UPMM019
  • 217 POSTS
How much do you think something like that would run for parts/labor, etc
Is this a repair that can be DIY or I really need the service shop to do it?
Jul 8, 2014 at 12:37 PM
UPMM019
  • 217 POSTS
Also, is that the same as the A/C Accumulator ??
I was trying to find the part on Autozone for Receiver Dryer but nothing came up but I did find A/C Accumulator.
Jul 9, 2014 at 2:21 AM
  • 110,251 POSTS
The A/C Receiver Drier and A/C Accumulator are different components. They serve to keep liquid out of the system's track. The accumulator is located on the evaporator, where the refrigerant exits to the compressor. The accumulator traps any refrigerant leaving the evaporator in liquid form.
Jul 9, 2014 at 2:01 PM
UPMM019
  • 217 POSTS
Where is it located?
Is it up by the firewall or elsewhere?
Jul 9, 2014 at 3:36 PM
